Originally posted by Blue.:R32
View Post
Possible DSG Mechatronic Issues
Just like riding a motorbike.....set your gear for the exit of the corner, before you actually get to the corner....trail the accelerator through the corner, gun it at the apex/exit.MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
Thats the same as driving lessons i had in the car as well. You are meant to select the gear and have it completely engaged before the corner.Originally posted by FJ Steve View PostJust like riding a motorbike.....set your gear for the exit of the corner, before you actually get to the corner....trail the accelerator through the corner, gun it at the apex/exit.
DSG allows you to change in the corner because it changes so quickly. This is often mentioned in the reviews as they have the ability to change gears in the corners without unsettling the car.Originally posted by G-rig View PostThats the same as driving lessons i had in the car as well. You are meant to select the gear and have it completely engaged before the corner.website: www.my-gti.com
It may be able to but don't think that's good practice and would still unsettle it. Choose your speed for the corner first!Originally posted by Maverick View PostDSG allows you to change in the corner because it changes so quickly. This is often mentioned in the reviews as they have the ability to change gears in the corners without unsettling the car.
This may be so, but my experience in the TDI would indicate that in some circumstances the mid-corner gear change and consequent change in torque does unsettle the car. Having said that, the DSG is extremely competent and smart enough in D or S mode not to pull a stunt like that, anyway.Originally posted by Maverick View PostDSG allows you to change in the corner because it changes so quickly. This is often mentioned in the reviews as they have the ability to change gears in the corners without unsettling the car.
Why? The reasons for not changing mod corner are no longer valid with a DSG, there is no interruption to power and the car will not become unsettled. If the car can safely change gears mid corner and this gives it an advantage why not use it?Originally posted by G-rig View PostIt may be able to but don't think that's good practice and would still unsettle it. Choose your speed for the corner first!website: www.my-gti.com
Funny enough my DSG feels like a normal manual when turning. As in I feel the power cut, clutch engage, gear change, power restored. Strange happening IMO.Originally posted by Maverick View PostWhy? The reasons for not changing mod corner are no longer valid with a DSG, there is no interruption to power and the car will not become unsettled. If the car can safely change gears mid corner and this gives it an advantage why not use it?2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
maybe not in a 32 and not so much on a ko3 either but if you're in a higher gear changing down into a peaky powerband would unsettle the carOriginally posted by Maverick View PostWhy? The reasons for not changing mod corner are no longer valid with a DSG, there is no interruption to power and the car will not become unsettled. If the car can safely change gears mid corner and this gives it an advantage why not use it?
That would be because you have a tractor, you barely notice any interruption in power delivery on the GTI.Originally posted by maca View PostFunny enough my DSG feels like a normal manual when turning. As in I feel the power cut, clutch engage, gear change, power restored. Strange happening IMO.website: www.my-gti.com
Ahh yes that must be the technical explanation.Originally posted by Maverick View PostThat would be because you have a tractor, you barely notice any interruption in power delivery on the GTI.
It's quite ok to say "I don't know" in these sort of situations.Last edited by maca; 17-11-2009, 10:34 PM.2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
The DSG changes at the same speed no matter what it's connected to. If the TDI feels sluggish between gears (like the one I drove today) than I don't think it's unreasonable to make that assumptionOriginally posted by maca View PostAhh yes that must be the technical explanation.
If they behave the same regardless of what they're connected to, it shouldn't matter weather it's a TDI or TSI.Originally posted by Maverick View PostThe DSG changes at the same speed no matter what it's connected to. If the TDI feels sluggish between gears (like the one I drove today) than I don't think it's unreasonable to make that assumption
Except it does. Both engines have different characteristics and this affects the DSG operation, I assume that's it's down to torque, speed of the engines etc.Originally posted by maca View PostIf they behave the same regardless of what they're connected to, it shouldn't matter weather it's a TDI or TSI.
"Having spent extensive time in both a GTI DSG and my car (TDI DSG), I'd say that the DSG coupled to the 2.0T in the GTI definitely shifts faster. But, it also shifts differently. It's hard to explain, but it just shifts differently compared to my TDI."website: www.my-gti.com
Fair enough. After all, our TDIs aren't really made for perfomance.Originally posted by Maverick View PostExcept it does. Both engines have different characteristics and this affects the DSG operation, I assume that's it's down to torque, speed of the engines etc.
"Having spent extensive time in both a GTI DSG and my car (TDI DSG), I'd say that the DSG coupled to the 2.0T in the GTI definitely shifts faster. But, it also shifts differently. It's hard to explain, but it just shifts differently compared to my TDI."Last edited by maca; 18-11-2009, 12:37 AM.2002 Volkswagen Bora V5 - 2007 Mazda 3 GT - 1998 Ford Contour Sport - 2010 Volkswagen Jetta 2.0T - 2013 Volkswagen Passat 130TDI - 2015 Ford Escape 1.5 - 2016 Subaru WRX - 2018 Volkswagen Golf R Wolfsburg Wagon
