Hi guys
I just experienced a puncture on my passenger side rear tyre. The flat tyre indicator light lit up on my dash with the audible "bing!". I knew something didn't sound right either even before the sound happened.
Anyway, I pulled over at the nearest servo I could and put some air in firstly. Put 35psi in to see if my tyre had just gone flat and needed sme more air or if it was a puncture. After the air was put in, it made a very loud hissing noise and so I knew it was the tyre that was fked. I jacked the car up, put the spare wheel on and put the wheel back in the boot
When I started the car up again, it started up and i heard the "bing" again. the indicatr light was still on!! I tried pressing the button next to the ESP but it wouldn't do anything.
My question is....WHATS WRONG WITH IT?! WHy wont it go away even after I changed the wheel and put air in all 4 wheels just to make sure theyre pumped up? I can't see why the indicator light is still on....
P.S none of the other 3 wheels are flat by the way. and I also turned the ignition off, took the key out and started the car up again 3 times.....and all 3 times it made the same noise saying there is a flat tyre somewhere when there aint.!
