Just a quick question, that google and wikipedia failed to answer.
Whats the standard revlimit of a Mk4 Gti 1.8?
I believe the fuel cut is 6.7-6.8 but I just head that on a forum.
As for shifting point, normally you want change at around redline.. You want to shift at the point where you will retain the highest area under the torque curve. Its all about retaining a higher average..You want the most torque possible in the next gear coming.
When you shift from 3rd to 4th, the torque at the wheels is lower. (EG 600N atw in 3rd @6000, that the same rpm in 4th it may be 400) If you change at a point where the 4th torque will be 500nm you will have a better acceleration rate)
The manufacture usually would have geared the car to perform best with a change at redline (NOT FUEL CUT) Normally that will drop you back nicely onto a nice lump of torque.
There is no point changing at 6800 if the torque has already peaked or tapering in the following gear. You will be well and truly out of the range in 3rd and already over the hill in 4th.
