RCD510 Head Unit
  • RCD510 Head Unit
    Hi Folks
    Does anyone know where I can source an RCD510 head unit? I have an MY09 GTI with an RCD500 and I'd like to upgrade.
    Any leads appreciated.
    Thanks
    Gus
    Hi Gus, check out ebay in UK, beware of the sellers from Slovania, Czech republic etc since some of them could be fake... but if you can gather good rating from UK sellers, they usually go for around AUD$1000 or sometimes less. Good luck.
    Here are a few I've looked at and obviously bidding finished:
    Another one:
    Both from same seller.
    2009 .:R32 • 5Door • Black Magic • DSG • Sunroof • Stubby Antenna
    2007 Honda CBR1000RR Fireblade • Yoshimura RS5 Carbon Fibre Pipe
      i agree completely with the above sentiments.
      i got mine from ebay (UK) paid just under 500 pounds shipped.
      mine was from a 2009 Passat CC, and was shipped with the manual, and the code card.
      arrived in about 10 days, and was in mint condition.
      just make sure that you check the feedback ratings of any prospective seller.
      it's a good way to get an idea of the sellers trustworthiness.
      also, pay with PAYPAL if possible, using your CC.
      that way if anything goes wrong, you have two lines of insurance.
      one via paypal, and the other from your CC company.
      Jason.
      05 Golf 1.9 TDI comfortline DSG
        A lot of the head units are made in the Czech Republic so it's not uncommon for most of them to be sent from there. Tomy who sells a lot of RNS 510's is based there.
        website: www.my-gti.com
          I just upgraded my Tiguan from a RCD 510 to an RNS 510.
          The guy in the service department - mentioned something about CANBUS though - and said that if people had a RCD310 they could literally plug and play the RCD510, but not if they had a "00" series headunit as CANBUS was different?!
          That make any sense to those here in the know?
          2009 147TSI Tiguan, Deep Black Pearl Effect, Black Leather, Sunroof, RNS510, Bluetooth, and MDI.
          Delivered 22 May 2009
            Hmm I'd be interested to know as well DJY.
            I'm looking at upgrading my RCD300 to an RCD510, just going off the ebay link posted by aristocrat above, I noticed someone has asked the question
            Q: Hi I currently have a rcd300 in my mk 5 2004 golf. Will this rcd510 fit and work fine? Also to connect my ipod classic is there a lead I can get to plug...more
            A: Chances are that you will need a CANBUS adaptor to update your CANBUS gateway otherwise the RCD510 will drian your battery. Apart from that, the RCD510 will...more
              You might want to read this thread then Cam!
              I was searching around the forums...
              before I just put up a PRICE CHECK thread for my RCD510 in the classifieds section.
                Thanks
                So, according to that thread you only need the CANBUS upgrade if you have an MY05/06 or prior? If thats the case I might be ok, mine is MY07
                  MY 07 will still probably need the upgraded gateway.
                  if your car currently has a RCD310 head unit (as opposed to the RCD300)
                  you might not need the new gateway.
                  if you have the RCD300 (most likely you do) you will need the upgraded unit.
                  easiest way to find out is to either scan the gateway with VCDS / VAG-COM or physically look at the unit to see it's part number.
                  you need part number 1K0 907 530 with the revision L or later.
                  ie: 1K0 907 530 L. the one i bought is 1K0 907 530 S.
                  hope this info helps.
                  Jason.
                    Thanks for the info Jason
                      i have one for sale that will fit. PM me for details.
                      <VW Passat R36 Sedan>
