Hey guys i profess to not being an expert on tyres or rims, as such but giving consideration to
replacing my stock 18" Zolder r32 rims with something aftermarket.
I've done a ton of research but think it is best if i sought the advice from
the more then helpful folk on this forum.
Basically i have my eye on some enkei's to be particular;
Enkei GTC 01 Wheels
My question, is will these be a perfect fit;
From what i understand the OEM Zolder R32 rims are;
18" x 7.5 width, 51mm offset
Stud pattern: 5x112
Tyre Diameter: 225/40/18
The enkeis are;
18" x 7.5" 5/114.3 48 (offset)
So the only variable is the offset figure.
Will these be a perfect fit, id prefer not to have the wheels stick out
of the guard or basically not enough clearance for the brakes or suspension
components.
Am i to assume also that if i chose instead an 18" x 8" width rim style it would protrude?
Lastly, i read about the HUB centric ring, do you guys think they will be of the same diameter.
Will modifying the rims cause any havoc to the TPMS system?
I guess it would be comforting to know if anyone here has fitted ENKEI rims or these specific ones on their R32.
Thanks guys, and feedback is appreciated.
Enkei GTC 01 Wheels
Stud pattern: 5x112
The enkeis are;
components.
