Mk5 1.6L only runs on 98RON!?!?!
  • Mk5 1.6L only runs on 98RON!?!?!
    I was talking with a friend who has a mk5 Golf with the standard atmo 1.6L and he told he that when he bought the car the dealer said you can only run this car on premium 98 Ron unleaded. Is this true? I didn't think that the 1.6 was in such a high state of tune to warrant such an expensive fuel.
    Anyone out there running standard unleaded without problems.
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
    I think it might be 95 but yeah it's premium.
    Such a rubbish engine.
      all the petrol mkv golfs are recommended to use 98ron with 95ron as a minimum.
      84 MK1 GTI
      01 DC2R
        The Golf V Specifications that were previously on the VWA site said 95RON for the 1.6 and 98RON for the other petrol engines. Anyway, it will be listed inside the filler flap on the car.
          Is the friend capable of reading their owners manual conveniently located in the glovebox or even of reading the inside of the fuel filler cap Because if he did he would see that VW recommend 95 RON fuel.
          Is 10c a litre really that much more expensive? The car uses 7.5l litres/100km so assume 15,000km pa this is 1125 litres. Additional cost each year to use 95 or 98 RON fuel $112.50 plus it can lower your fuel consumption and keeps the fuel system clean.
          website: www.my-gti.com
            Higher RON only means the fuel will not detonate at lower compression rates. The 1.6 has a relatively high compression compared with say a Corolla, but a heavier car to pull around. It needs all the help it can get (which explains why it has been replaced in the MK6 with a turbo...).
            (formerly TSI GUY)
            First car: 1972 White Super Bug S
            First Golf: MY08 Candy White Golf GT Sport TSI DSG
            Now: MY13 Candy White Golf VI 2.0 TDI DSG (yes, I've come over to 'the dark side'...)
              lol..my mighty beast is a 2000 1.6 atmo car and I usually use PULP but it seems to run fine on regular unleaded as well.
              My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
                The Corolla's 1.8 has made 100kw for years, the Golf 1.6 made what? 74kw iiirc?
                  75kw and 148nm. Compression is 10.5:1. There was a 1.6 FSI from memory in Europe, I wonder what sort of power that made? The 2.0 FSI puts out 110kw and 200nm so it couldn't have been a big increase.
                    I found that my old mkIV 1.6 was a lot happier with 98RON.
                    95RON was the recommended minimum.
                      Power - 75 kW @ 5600 rpm
                      Torque - 148 Nm @ 3800 rpm
                      Compression ratio - 10.5:1
                      1.6 FSI
                      Power - 85 kW @ 6000 rpm
                      Torque - 155 Nm @ 4000 rpm
                      Compression ratio - 12.0:1
                        You can run the car on slurry standard unleaded, but it clogs up the fuel system and will crack the exhaust manifold etc. And it will run like a slow old pig.
                        It costs the same to run the car on premium as the engine runs better and doesnt labour as much. I reckon you spend another $2 at the pump and go 50ks further.
                          In Germany you can still get the Golf VI with the 1.6 (75 kW) and on their website it says you can use premium unleaded OR regular unleaded, but in the fine print it says that using regular may result in performance and fuel consumption penalties [yep, you can actually buy regular unleaded (91 RON) in Germany].
                          However German petrol is very clean, as all grades of petrol have a limit of 10 ppm for sulfur, but in Australia regular is allowed to have as much as 150 ppm of sulfur, while premium has a limit of 50 ppm of sulfur. And for that reason alone your friend should always use premium (95 RON) or super premium (98 RON).
                            One of my workmates borrowed her daughters NA MK5 for a month and filled it with ULP all the time she had it. Her daughter thought there was something wrong when she returned from overseas and took it to the dealers for diagnosis - it only cost her $100 for them to tell her it had incorrect fuel in it
                              They should cancel the drivers license of people that are too stupid to RTFM or read the inside of the fuel flap. Why would you fill a car up with fuel not knowing what fuel was required, you may as well put diesel in it.
                              I can see in years to come drivers will be so stupid they will create nozzles out of different shapes to prevent these problems. If the parents can't fit the correct nozzle at least they can get their two year old out to do it for them
