I know that there is a way that you can get the actual speed of your car using the Climate Control, but this stops after 100km/h.
As I was driving to Melbourne the other day I had time to wonder about how fast I was actually going and came across this .. sorry of posted before.
While going the speed you want, set cruise control and then reset the MFD by holding down the OK button on the steering wheel (for GTI - not sure about the others). This will reset your fuel, time engine running etc AND the average speed you are going. About two seconds later the average speed will be calculated and as you have not changed speed it will be your actual speed.
In my case the speedo was a tad under 120km/h on 110km/h speed zone and the MFD average speed was showing 111km/h. By way of a check, coming in from Adelaide on the freeway it shows you your speed and at the same speed as above I displayed at 108km/h.
Hope this can help someone fine tune their higher speeds to know "reasonably well" what speed they are doing. I expect but haven't tested that this speed correlates with the Climate Control speed but expect it would.
