Using standard rubber etc refill.
1.Unclip blade assy from arm
2.Open side tang and slide off centre blade to arm holder
3.Slide rubber blade into assy and squeeze end slides together allowing end cap to be removed.
4.Squeeze same on centre part and remove centre cap.
5.Remove old rubber blade and cut new to same length (ensure profile is the same 1st)
6.Slide new rubber between slides and slip on end cap(s) If loose/worn put a drop of glue into cap to hold to blade.
7.Clip on (slide over) centre cap to mate with 2 cutouts in slides.
8.Slide on arm holder.
9.Reassemble to arm on car and slide cap over dowel.
10.Test out.
Bazzle
10.Test out.
Bazzle
