I’ve experienced a strange fault on a handful of occasions in the 2 ½ years I’ve owned the Jetta and it happened again this morning.
Under acceleration from low speeds (tight roundabout or give way sign for example) using about half throttle i.e. not enough to kick DSG down to 1st gear, the engine momentarily cuts out, the car slows then the engine fires again and I accelerate normally. I’ve noticed this usually occurs on cool mornings when the car has been running for about 15 – 20 minutes.
This morning it occurred again only this time the engine cut out completely, I rolled to a stop and tried to restart, the engine cranked over but would not fire. I switched the ignition off, waited 3 or 4 seconds turned the key, she fired up again and drove off with no further problems.
Fuel tank was ¾ full, running BP 98 Octane fuel, engine temp normal, car has 55,000 KM and is serviced as per schedule.
Anyone experienced anything like this?
George
George
