Help: Golf GTI with 16" wheels?
The OP has a specific issue with a speedbump damaging a tyre. The tyre tests are still the best way to guage a tyres performance, I don't run over potholes every day whereas I do brake every day in the wet and dry and corner and accelerate. As you said tyre pressures will come into play more then anything else when you hit a pothole and also have a big effect on handling.Originally posted by brad View PostI agree that controls are required for testing purposes but in this case, the OP hasn't asked about grip, wear, wet or dry braking, etc and has a specific issue with driving on unmade or secondary roads & damaging the tyre. The tests really don't cover that, do they?
Everyone has decided that this is a sidewall issue and are recommending different tyres when there is no mention of a sidewall problem and there is nothing to indicate that the CSC2's or CSC3's are any more prone to sidewall damage then any other similar tyre.Originally posted by Unbelievable View PostNow last week I damaged one of the front tyres (a Continental Sport Contact 2) on a stupidly designed speed bump
As I said I'm basing that on seeing no posts about sidewall damage with the CSC2's!In some ways you contradict yourself as you recomend looking at the tests and then immediately introduce your personal, non-tested, anecdotal experience regarding sidewall damage (just like the rest of us
This thread to start with.Originally posted by Maverick View PostEveryone has decided that this is a sidewall issue and are recommending different tyres when there is no mention of a sidewall problem and there is nothing to indicate that the CSC2's or CSC3's are any more prone to sidewall damage then any other similar tyre.
posts 5, 7, 9.
While the OP hasn't stated it, from my experience, 99% of the time an impact will damage the sidewalls as they are significantly weaker than the tread area.
Several people have mentioned the sidewalls & nobody (bar you maybe) has mentioned the tread area. The OP has revisited the thread & not contradicted our assumptions.
I run CSC2s on my car (55 profile) and they are great tyres, but there is no doubt that the sidewalls aren't as stiff or heavily built as other tyres. Under normal use, they are fine but on secondary roads I believe there is a greater risk of getting an impact fracture CSC2 than some of the other brands on offer.carandimage The place where Off-Topic is On-Topic
Just to clarify: it was sidewall damage. But I forgot to say that in the original post.Originally posted by Maverick View PostI can't find where he said anything about the sidewalls being the problem? All I can find is him saying that he had to get a tyre replaced because of a speed bump?2008 MkV GTI BG Tints
I run at about 10% over the recommended pressure that is on the sticker on the back of the fuel filler cap.Originally posted by brad View Post...
One thing that I haven't noticed anyone asking the OP.
What tyre pressures are you running? As this will have an impact on the resiliance of the tyre sidewall.2008 MkV GTI BG Tints
Originally posted by gregozedobe View PostA lot depends on your what you mean by "dirt" driving. If it is a short distance on smooth dirt roads (not much in the way of rocks over 50mm in diameter) then a change of brand in tyre is probably all you need. If it is a long drive on a truly rough dirt track then maybe a GTI isn't the right vehicle for that sort of driving ?
The "dirt" driving is about as you describe. I agree - the GTI is not the right car for a very rough track. However, I have been driving a Subie Outback for the last few years so I got kind of used to driving quickish on dirt. I might need to re-evaluate that approach
That should be OK then.Originally posted by Unbelievable View PostI run at about 10% over the recommended pressure that is on the sticker on the back of the fuel filler cap.
There is always the possibility that your tyre damage was just one of those things & the likelihood of it happening again is quite low.
maybe buy 2 new brandX tyres & put them on the back. Keep the other CSC2 front as a spare in the garage. Run the CSC2 that are on the rear up front - if you damage another then you have a spare. Maybe it will never happen.carandimage The place where Off-Topic is On-Topic
Judging by your thread re GTI wheeels I'd guess you had no luck with getting your original wheels back. I wonder would it be against forum rules to name the tyre place that gave this advice to you?Originally posted by Unbelievable View PostAll I can say is
George06 Jetta 2.0TFSI Killed by a Lexus!
14 EOS 2.0 TSI has arrived!
Yeah you are right - they had already sold them to a dealer who had put them on a car - which had been sold: all between 12:30 on Saturday and 12:30 on Monday.Originally posted by VW Convert View PostJudging by your thread re GTI wheels I'd guess you had no luck with getting your original wheels back. I wonder would it be against forum rules to name the tyre place that gave this advice to you?
If it's not against the rules, I'm happy to name names, but I'll wait 'till I've sorted this mess out so that I can tell the good and the bad.
Cheers,
B2008 MkV GTI BG Tints
sounds like they purposely "traded" your wheels to make some extra cash from the dealer......Originally posted by Unbelievable View PostYeah you are right - they had already sold them to a dealer who had put them on a car - which had been sold: all between 12:30 on Saturday and 12:30 on Monday.
Cheers,
B
sounds dodgy!!!! super dodgy!!
oh god, you're in Melbourne too! where is this place?? pm me if you want?
If the wheels and tyres are not rated for the GTI, you may have recourse available as the tyre service has a responsibility to sell and fit only wheels and tyres that are rated for the car. I would be checking out whether the wheels and tyres are in fact legal for the GTI and if not take it to fair trading or a solicitor to ascertain your status.Originally posted by Unbelievable View PostYeah you are right - they had already sold them to a dealer who had put them on a car - which had been sold: all between 12:30 on Saturday and 12:30 on Monday.
Cheers,
B
