its actually weirder than that too.... when plugged into the lamp holder but the assembly out of the car it works... put the assembly into the car and it wont work... only fix is a replacement globe.
Replacing Rear Brake Lights
Originally posted by Maverick View PostNooooooooooooooooooooooooooooooo
For a start LED replacement tail lights make your car unroadworthy (note not talking about the replacement OEM LED housings but the cheap useless plug in replacements)
They won't work correctly with the Golf anyway with the single filament setup.
LED replacements don't put out anywhere near the amount of light as the incandescent globe as the light fitting and reflector was designed for a incandsescent globe. Every OEM LED brake light you see has the LED's facing directly backwards NOT being bounced into a reflector and then backwards.
Reliability of the LED units is often an issue as they are not well built and you can lose parts into the housing.
Sorry but it's a shocking suggestion for any car not just the Golf
Ive been using them on some Mercedes models very sucessfully. I can see you've had an issue... each to their own.
BazzlePrev 2008 R32 3 door DSG.
Prev 2010 S3 Sportback Stronic.
Now Lexus IS350 F Sport
Not so much that I've had an issue with them but more so that they just don't work properly. And no matter what you do you can't get over the issue of the reflector design. They're another one of those good ideas on paper but rubbish in practice.Originally posted by bazzle View PostIve been using them on some Mercedes models very sucessfully. I can see you've had an issue... each to their own.
Bazzlewebsite: www.my-gti.com
