Yesterday, cold start in the morning, once I roll out my garage, I got "STOP check Coolant" then the coolant warning light keep on flashing, until I stop the car and then its gone ... until today its not happening again ... check the coolant, no problem with level over the top line, anyone know if i have a fault sensor?
Check Coolant warning ON!
What sort of VW? Where do you live?
I believe the fill from the factory to Oz is near the sensor low limit. If the morning is real cold it may illuminate. As soon as the coolant expands a bit the sensor reads ok.
I assume you opened the bonnet and visually checked the level??
BazzlePrev 2008 R32 3 door DSG.
Prev 2010 S3 Sportback Stronic.
Now Lexus IS350 F Sport
Was the coolant level significantly above the max level ?
You can also get this warning if engine oil gets into the coolant (says he from bitter experience with his TDI).2017 MY18 Golf R 7.5 Wolfsburg wagon (boring white) delivered 21 Sep 2017, 2008 Octavia vRS wagon 2.0 TFSI 6M (bright yellow), 2006 T5 Transporter van 2.5 TDI 6M (gone but not forgotten).
