Its a bit better.
105 at 100 indicated now instead of 108 (gps used to check)
Engine revs still at 2500rpm.
Pic below is a page dump of VCDS screen.
As you can see there are a few options to adj speedo pulses from can to inst cluster.
Adding the 7 on the end is the best you can do. My ozzie R32 came with the 3 option.
I tried some other numbers to prove it works and was doing 100kph at 2000rpms on No 4
Left at 7 on end of number train for coding.
I also tried numbers that were not listede but it would not accept any (hoping to reduce error further
Also added Rain closing windows and roof, alarm beep on activate and deactivate, fiddled with the alarm noise but only got a higher pitch one so went back to OE.
Bazzle
)Also added Rain closing windows and roof, alarm beep on activate and deactivate, fiddled with the alarm noise but only got a higher pitch one so went back to OE.
Bazzle
