Hi,
The air conditioning is not functioning in the 2005 Golf 2.0L FSI Automatic.
When I switch on the A/C and the blower, the A/C fan does not turn on. I'm uncertain if the compressor has a clutch; there is a control valve connected to the back of the compressor with two wires, but I don't see any other wiring connections to a clutch if one exists. When I turn on the ignition switch, I measure around 5V on one of the wires. I can see the high-side pressure switch, but I cannot locate the low-side switch.
There was very little refrigerant gas in the system. I safely evacuated and recharged it with Hychill Minus 30 after confirming there were no leaks during the vacuum process. However, the compressor did not engage, and I observed 80 psi on both the high and low sides. Additionally, the refrigerant paused halfway while entering the system.
I would greatly appreciate any assistance in troubleshooting this issue. Furthermore, if possible, please provide the wiring diagram for the A/C, along with the locations of the relays and fuses. Thank you!
