MKV R32 power in engine bay
  • MKV R32 power in engine bay
    hi just wondering if there are any cables or places to attach a new wire to, that has 12v, located some where under the hood
    thanks
    What are you hooking up?
      thanks
      The battery would be a good start.
      Knowing what you're doing would be a bonus unless you want to frig something up $$$$.
      website: www.my-gti.com
        Battery is in the boot, but there is a major battery "intersection" under the hood - its used for jump starting etc - a quick look in the owners manual will guide you in the right direction!
          sorry should of said what im hooking up, trying to install some of the audi led lights, but i dont no what wire to tie it to, coz there is no plug for them just wires
            Well don't even attempt to do it then, if you can't find the battery terminals/fuse box under the cover and don't know what to wire it to then I'd step away from the car and close the bonnet before you screw something up bigtime.
            Get some help from someone who knows what they are doing (and not someone who works on older cars either).
            For a start when do you want the Audi led lights to come on? Do you want them on as DRLs? This will require wiring and programming.
              Mate, these things aren't plug in and play items...You WILL need a decent Auto Sparky who knows his was around your car to be able to hook these into the correct lighting circuits.
              If you attempt to do this yourself and you don't have the appropriate knowledge, you can (and will) be faced with a massive bill to repair and replace burned out wires and circuitry.
              Trust me, you don't want to let the smoke out of your electrical system in a car like this...
                Agreed, best to let an Auto sparky do it. There are a couple of terminal intersections in the engine bay where the power to the starter / alternator / lights ets split, but in the case without the full wiring diagram, you may cause damage
