O2 sensors in golf gt
  • O2 sensors in golf gt
    Are these sensors wideband or narrow band on the golf gt 1.4TSI 170HP?
    I saw 4 wires coming out of it. White, white, balck and grey.
    Which one is the signal wire?
    Black is sensor, 2 white are heater, grey is prob common
    Bazzle
    Prev 2008 R32 3 door DSG.
    Now Lexus IS350 F Sport
      Ya, after reading up, I was gussing that the black one is the signal wire.
      But it is wideband (0-5V output) or narrowband (0-1V) output?
        Interested in this also... are u thinking of whacking an A/F ratio gauge on it?
        *Disclaimer - Don't rely on me, seek your own professional advice. Audi R8 E-tron. 230kw 4500nm! (not a typo).
        Economy at 100kph =5.5L
          Just about every factory fitted OEM oxy sensor I know of is narrowband.
          Although some car's do have a wideband before the cat. convertor & a narrowband after it.
          Why. Cause the tune is just about spot on & there's only a very small amount of fluctuation between rich & lean that the ECU has to contend with. Even if there's an air leak eg. split intake pipe, it will normally fault "oxy. sensor reading too lean"
          Where as with a wideband, you can tune all the way too stupidly rich & extremely lean.
          Narrowband are also a fair bit cheaper & last a hell of alot longer the wideband in my experience.
            Yes, you are right. I have a narrowband A/F gauge sitting there in the middle of a 3 gauge pod. Thinking of DIY the connection.
              An a/f ratio is only useful if you are having minor driveability issues and want to check whether its the oxy sensor.
              I can do this via my Scanguage 2 as it shows readings for both oxygen sensors in real time simultaneously.
              I have oxy 1 and oxy 2 setup.
              So i can see before and after cat readings and see if they are what htey normally are.
              To be honest, by the time a lean out event happens its too late to stop it. You will hear a bang and damage is done. Gauges are useful for small faults but catastrophic failures wont be stopped.
                I understand. I would like to hook it up anyway since I already have the gauge sitting there. Just need to connect the signal wire to the correct O2 sensor wire, that's all. So gathering some info and feedback.
                  Be very interested to see your setup once its installed and get your review of the readout.
