Aircon not working
  • Aircon not working
    Hi guys,
    The aircon in our 2006 mk5 golf isn't working. I bought a couple a cans and a regas lead/gauge off ebay, but when I plug into the aircon system, it's showing 100psi.
    Feels like its going to be an expensive fix, not just a regas. thoughts?
    thanks in advance
    Mine is bung too, well it works after a quick drive but will never get cool at idle.
    Have you scanned the car for codes with VCDS ?
    AC systems never just need a regas, the gas is not consumable it should last forever, if it is low on gas then it has escaped and the leak is the issue that needs to be fixed.
    Compressor control valve is the most common failure on these. Check radiator fans too if you just have bad performance.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
      VW compressors of that era are prone to failure. If you catch it early, you can minimise the expense somewhat. I drove my Tiguan too long after I knew something was wrong, and the entire system ended up with metal shaving and needed flushing. I'd get to an air conditioning specialist ASAP.
      Daily: 2010 Tiguan TDI | Candy White | Manual | 4MOTION | New York Wheels | Comfort Pack | Tinted Windows | Discover Media | MkVI MFSW | Mk7 Climatronic | RVC | Fog Lights | ECB Nudge Bar | Hella 160 Driving Lights | Rola RBXL135 Cross Bars | To Do: Colour MFD
      Toy: 2008 GTI Pirelli | Sunflower Yellow | 3 Door | DSG | Pirelli Wheels | RNS-510 | 9W7 Bluetooth | RVC | Rear Sensors | Fog Lights | To Do: Mk7 Climatronics, MkVI MFSW, Colour MFD
        thanks
        thanks for the responses. probably time to get a new VW.
          I replaced my control valve in the compressor. Bought it off eBay, and I have a mate who does A/C. He took the gas out, we replaced the valve and gassed it back up again. The valve was like $30. If you buy it and provide it to an A/C shop, they may change it for you for a regas cost.
          I put a post in here about it.
          Richard
          2007 Black Jetta 103TDI Manual, 18s, body kit + rear spoiler
          2001 Landcruiser FZJ105 Manual - The petrol guzzler!
            as mentioned, they are prone to failure, identical ones can be purchased new for around $600
              I got my ac fixed today.
              Compressor $650
              Dessicant (receiver drier) $15
              Gas $75
              Cabin filter $35 (did not need doing was only 3 months old), paid anyway got the old one back knocked out the leaves, will use it in 2 years time.
              Labour $425
              Total $1200
              Works just like it used to, not nearly as good as a toyota but hey what do germans know about AC ??
              Ac shop says yes the valves fail but only because the compressor gets an issue that causes the valve failure. They have 50/50 success rate changing them usually people come back within a few months with a failed valve. New compressor is different design will not cause the valve failure (time will tell)
              If anyone wants a new valve I have one, drop me a 6 pack and its yours.
              MK4 GTI - Sold
