Removing airbag system
  • Removing airbag system
    I'm making a mk5 race car and need to remove all airbags.
    Can I remove the airbag control module without putting the car into limp mode?
    Sent from my CPH1611 using Tapatalk
    Airbag controller doesn't cause limp mode.
      That's great news, so I can just pull it out with no effect other than the airbag light turning on?
        2nd that, it'll just throw an airbag light. You can also code out all airbags individually with VCDS.
          Thanks for the help that's great. Was concerned about the connection from the airbag module to the fuel pump.
