The mk5 door lock failure seems to be a common issue, but from what I can see there is very little info on how to actually fix one of them - rather than just replacing the whole unit. Of the 3 door locks that have failed in my 06 Jetta all 3 were due to the issue described in this DIY - this doesn't mean there aren't other ways they can fail, and so I have included some basic diagnosis steps. The DC motor issue was originally suggested by Saabman a while back in another thread and so thanks to him for making this DIY possible!
Symptoms for this failure mode
- Door intermittently locks and unlocks
- If you listen closely around the door handle you should be able to hear some sort of sound when unlocking/locking the car. If after multiple attempts you can't hear anything it might be worth checking the door wiring harness first.
Step 1
Remove the outer door skin and the door lock actuator, this has been well described elsewhere so I won't go into that here, a good tutorial can be found at shopdap.com
Step 2
Now the lock is off the car we need to separate the two halves, there is a mechanical and electronic side - the electronic side will be the focus of this DIY. Start by removing the T20 screw.
Followed by the smaller torx screw, I didn't have a bit this small but a 2mm flathead screwdriver seemed to work fine (it's not in too tight).
Unclip the two tabs either side of the small torx screw, and pull this lever back. The two halves should now separate.
Step 3
Open the electronics side by undoing the 8x T10 screws circled below. Whatever you do, do not undo the T20 in the middle of the red lever, it isn't fun trying to put that back together when it springs apart!
Step 4
With the unit open, it is now possible to diagnose the unit. To check the motors, measure the resistance across the metal prongs attached to them - it can be difficult to get a good connection so some scratching of the metal may be required. The value across the larger white capped motor should be about 3-4 ohms, I have had it read 40-100 before repair. The small black capped motor seems to be reading about 20 in this case, but it may be due to the coating applied to the prongs. In any case, given the larger motor seemed off I just decided to clean out both since I already had the unit apart although it may only be necessary to work on the larger one. To check the microswitches use the continuity function on your multimeter. Touch the leads on the two outer pins of the switch, and depress the switch to check for switching - i.e. if it starts as continuous it becomes discontinuous when depressed or vice versa.
Step 5
If you are satisfied one or both of the motors is the cause, then the motor needs to be opened. The motor is held together by two metal tabs around the plastic cap. In order to open the motor I used a small flathead screwdriver and weakened the tabs by grinding part of it with a dremel as shown. The area of metal casing around the tabs does not seem too critical so don't stress too much about messing it up.
After bending the tabs out of the way the plastic top should just slide out. Here is what you should expect to find (the smaller motor wasn't as dirty as the larger one). As for why the motors are so dirty I am not so sure, some on other forums speculate they may have been manufactured in dirty conditions or grease and oil may have somehow found their way into them during manufacture.
Step 6
In order to clean the commutator ring I used 2000 grit sandpaper followed by a wipe down with isopropyl alcohol. IPA was also used to clean the plastic housing and brushes. After cleaning, reassemble the motors, I applied a small amount of super glue to secure the plastic piece back on.
Step 7
Now reassemble the electronics housing. The top cover should fit easily onto the bottom - if it is sticking up something is probably misaligned. Here are a few things that you may want to be mindful of:
a. Replace the rubber motor cover if you removed it when opening the motor
b. Make sure the pin is sitting inside the groove of the plastic piece below it. Also check that the black plastic bushing at the end of the worm drive is present and seated correctly.
c. Check the microswitch is positioned correctly. It should be either open as shown, or depressed by the white plastic piece to the right of it. It should not be sitting on top of the plastic piece.
d. Ensure the arm is correctly located on both posts, and in this case it is depressing the microswitch.
A reference photo of the lower section in case yours falls apart.
Step 8
With the electronics side back together the two halves can be joined again. Before mating the two halves, ensure that the position of the lever is the same as when you took it off the car. The two positions are shown below (in this case unlocked position was required). Failure to properly position it will result in the lock not operating. You can check proper operation by moving the lever to the lock position then pulling the lever that is attached to the interior door handle - the interior lever should kick the red lever to the unlocked position. Try this a few times to make sure nothing goes wrong.
Join the two halves together and replace the two screws. In order to replace the spring I found the best way was as follows. Position the spring as shown below, then use a set of small needle nose pliers to force the long end of the spring over the tab.
Summary
The unit is now ready to install back into the car, I highly recommend testing the lock thoroughly including interior door handles for a few unlock/lock cycles, as some problems will only manifest on the second or third try. After you are satisfied everything is operating correctly, replace the door panel and handle.
As for the longevity of repairs from this method, I am not 100% sure but can't see why they wouldn't last as long as it did originally (provided no other components fail) and have so far had one lock working flawlessly for 8 months. This repair is not too difficult, and I'd estimate the time to get the lock apart and back together again is about 15-30 mins, the time taken to separate the motors may take some time if you have never done it before but is possible to do in 5-10 mins.
Hopefully this helps someone out!
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
Step 8
Summary
