Which actuators are you referring to? The door lock actuator or something else? If its the door lock actuator then yes they are the same across all mk5 Golf/Jetta.
Dont throw your old ones out. The most common fault is the micro switches failing and the motors filling up with gunk. The switches can be replaced and the motors pulled apart and cleaned. It’s a bit of effort but some people say the Chinese ones don’t have a great life span so might be worth fitting them and then rebuild your old ones to refit when the new ones fail.
