When you unplugged all of the sensors and tested, did you also unplug the intake flap actuator?
Finding 1
Last weekend i unplugged cam adjustment solenoid (N205). It was funny to watch that commanded cam angle was fluctuating but actual was floating around +30 crank angle which should be mechanical lock to the most retarded position.
However car's behaviour persisted - high torque from cold engine to hesitation when hot. Maybe the knock control was enforced with intake flaps or base ignition timing??
Finding 2
Full tank of higher octane fuel 95->98 worked like a magic. Throttle response improved a lot. I have never seen such improvement even with 100 octane fuel taken from other petrol station. The change was literally instant within 1 tank and ~ 300 km driven. Cam adjustment during WOT stayed on -2,5. I learned on 95 octane that it dropped to -11 when there was going to be throttle lag. I guess intake valves stayed open awhile during compression stroke, deliberately ruining compression in cylinder = reducing power = protecting A/F mix from pre ignition?!
What version of Windows are you using with MPPS v16? I have a working software for it that works well on Windows 7/XP if you PM me.
I can confirm Kessv2 works perfectly too, in fact on my MED9.5.10 it writes in about 16 minutes vs the 38 minutes the MPPS v16 does. However both work pretty well on this setup for me
I managed to get my 1.6 FSI to 97kw (130whp) on my dyno through decat, intake, cam timing changes and making it run a LOT richer than VW did from factory, and putting more timing in. My stock tune would do what yours was doing and pull a load of timing, now I just get timing pull at low RPM but nothing I can do can help that with this high-compression engine.
