MK5 GTI Project Build
Hi all,
I'm Alex and this is the build thread for my MK5 GTI.
I currently own a 2008 MK5 DSG GTI in Tornado Red sitting at 145xxxkms.
At the moment the only modifications are:
- GFB DV+ (Was underboosting due to a tear in the old factory valve)
- Resonator delete and sports muffler with curved 3" tips
This build is going to take place over the next year and will hopefully be done in a relatively short time.
To keep it short it is going to be a reliable daily running a Stage 2 tune on stock internals with a possibility of upgrading to a K04 Hybrid turbo later down the track.
Specs of the Build
Engine
Air intake $147
Empire Perfomance Downpipe W/ High flow cat - $349
Redtop Coilpacks - $199
Sparkplugs (NGK BKR7EIX) $57.50
ECU and TCU/DSG Tuning
ECU Tune Unitronic Stage 2
TCU/DSG Tune Stage 2 (or whatever is required)
Uniconnect Cable+
Brakes, Wheels, Tyres and Suspension
Wheel Alignment (Beaurepaires did the last one and now the steering wheel hangs to the right, they insist it's the crests on the roads in our area even though it does it on dead flat roads)
Wheels 18" Detroit rims off a MK6 GTI (Seen them going for $400 for a set of 4)
Tyres (Thinking Bridgestone Potenza RE003 or Michelin PSS4)
Coilovers (to get started I shall be using some coilovers from eBay)
Dogbone mount polyurethane insert
Polyurethane bushing kit (if anyone knows one for a decent price let me know)
Interior
Re-trim door cards (urgent, they're falling apart)
Replace rear cup holders
Replace drink divider (VW bottle opener thing, if anyone knows where I can get one cheap would be great)
Replace window switches, light switch, mirror switch and fuel switch with silver trimmed ones (believe they come from the Jetta but eBay has cheap OEM ones)
Replace drivers door lock switch (Has a gouge in it)
Replace handbrake leather (Worn and keeps coming off)
Replace DSG surround (May just spray paint with matte paint)
Drivers aircon vent digital boost gauge
Replace mats with OE mat set
Done
150xxx Service (Including DSG oil service and HPFP cam follower replacement) Parts $236.50 Labour FREE
- DSG fluid
- Engine oil
- DSG filter
- Engine oil filter
- HPFP cam follower
- Air intake (Ebay Special, not bad quality and does the job)
- Detroit rims (Found some with tyres for $500 cash and will change them when they're spent)
- Wheel Alignment (Jax tyres are reccomended, turns out one front wheel has 1 degree neg camber and the other front wheel has 1 degree positive camber so I need adjustable camber bolts to fix this)
Pictures
20181025-143406 — imgbb.com
20190103-145854 — imgbb.com
20190103-145905 — imgbb.com
20190103-145912 — imgbb.com
Any advice and constructive criticism is welcomed.
Hi all,
Specs of the Build
Engine
Air intake $147
Uniconnect Cable+
Interior
Done
- DSG fluid
- Engine oil
- DSG filter
- Engine oil filter
- HPFP cam follower
Pictures
