Hi. I’ve been a member a year or so. Have not really posted much.
I wondering has any fitted a 12volt electric oil scavenger pump to their dsg external oil cooler.
I’ve done some research on the pumps and their flow rates. Which are approximately 14 litres per minute. Personally I believe this to much. So I also found a 12v motor speed controller ( pwm) which I will be able to control the pumps rate of flow to a more respectable 4-5 litres per minute.
My thoughts on installation would be fitting the pump on the return line and obviously correctly wired with a relay and suitable fuse.
If anyone has any thoughts about this or even if it’s good/bad idea.
I’d be happy to hear your thoughts.
