Originally posted by kdog
View Post
CV Joint boot cover
It should always be cleaned and new moly grease applied.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
I just had my two outer boots done last week for $180 per side as part of a service. I noticed the passenger side had split a bit like the first picture, but nothing like as much dirt around it. No idea how long it had been split. They inspected the joint and were satisfied there was no wear requiring replacement. Joints are still quiet. 145k kms TDI manual.Richard
2007 Black Jetta 103TDI Manual, 18s, body kit + rear spoiler
2001 Landcruiser FZJ105 Manual - The petrol guzzler!
Absolutely. When I replaced a boot on my T4, the grease had started to flick out. After I had removed the boot the grease looked good but knew I needed to clean out the whole joint [very dirty messy job]. As soon as I cleaned it I couldn't believe the wear as there was no noise from the CV. If I had just put a bit more grease & replaced the boot only, I would soon be pulling it back out again. There is a picture in this link.Originally posted by kdog View Postdo you recommend cleaning the CV joins completely and applying the new grease or just adding grease to the existing?
Drive Shaft Removal Procedure on T4 & CV joint servicingLast edited by jets; 09-05-2018, 11:02 AM.Understand how it works, troubleshoot logically BEFORE replacing parts.
Numerous Mk1 Golf diesels
awesome write up & good tip for removing the cv join.Originally posted by jets View PostAbsolutely. When I replaced a boot on my T4, the grease had started to flick out. After I had removed the boot the grease looked good but knew I needed to clean out the whole joint [very dirty messy job]. As soon as I cleaned it I couldn't believe the wear as there was no noise from the CV. If I had just put a bit more grease & replaced the boot only, I would soon be pulling it back out again. There is a picture in this link.
im not too sure how to remove the inner side though? and how come on T4 they dont have a end plate like we do?
it got realll messyy lol
The T4 was designed in the late 80s & first built in 1990. The design has evolved over the years & VW thought of keeping the grease close to the CV joint. The T4 has a cork gasket to keep the grease inside.Originally posted by kdog View Posthow come on T4 they dont have a end plate like we do?Understand how it works, troubleshoot logically BEFORE replacing parts.
