DSG transmission oil change
This topic is closed.
  • DSG transmission oil change
    I know its the general census that these tranny's are filled for life, however I cant help but think about all the metal shavings floating around in there...
    Has anyone had there DSG trans fluid changed? If so is it costly?
    I would only like to get it done after the first few thousand kms as after that I doubt there would be much more metal coming off the gears after the first few thousand kms...
    They're not filled for life.
    A fluid and filter change is required at 40k
      And you need special equipment to refill back up though the drainplug!!!
      I sourced mine through my dealer.
      Dont drain it unless you have the correct refiller and also the genuine fluid!!
      cheers, Andrew
        yeah I read it up on the net;
        you need to change gears with the engine running (obviously) with a drain tube in the transmission to drain the excess... How on earth do you do this ??? Might just pay the dealer to do it.
          And you need Vagcom to read the operating temperature as well as to when it overflows out.
          They make things tricky these days!
          Andrew
            Just spoke with VW dealer today, they said it is an 'optional' part of the 60k service, and costs $720.
            I might get it done at the first 15k service, so I wont need to get it done again as Im sure the first 15k on the fluid will be the toughest - majority of metal shavings etc.
            They said there is a magnetic seal on the sump plug that catches the metal, how well it works Im not sure....
              VW vag com software - http://www.ross-tech.com/vag-com/
              anyone used this on thier laptop with thier VW?
              Im looking into it as you need the tool to do a DSG oil change as u need to view DSG oil temps.
              You need to select each gear during the oil change procedure with the engine running, how do you do this while stationary??
                This is the exact reason I would leave it to the Xspurts....your dealer.
                From what I have heard...this is not a job for the weekend mechanic.
                MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
                2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
                  Actually I rang VW the other week and was advised by the service manager that none of the mechanics there had ever changed the oil in a DSG transmission!
                  Thats why I dont see any difference in myself doing it. Ive read the step by step manual - http://pics.tdiclub.com/data/517/DSG_40K_Service.pdf
                  All you need is the right tools - about $200 worth, this is still a saving of $500 from getting the dealership to do it.
                  The only thing Im stuck on is how do u change gears all the way up to 6 with the car stationary? Maybe once the VAG is plugged in it will let you .
                  I have a laptop and the cable, and I have downloaded the freeware of VAG COM which shows the DSG engine oil temp.
                    Well ... not something I would risk trying. If you stuff it up ... you've surely stuffed your warranty as well.
                    Dave
                      Ive found out the car has to be off the ground as u need to accelerate enough to get it to 6th gear, which I think is around 50-60kmph.
                      Im not going to try this with anything less than a proper hoist. so the project is on hold for now.
                        For heaven's sake man ... talk to your dealer before you try this.
                        Dave
                          The instructions don't say to run it through to 6th gear. It says:
                          shift into each selector lever position and hold it for about 3 seconds.
                          Which means put it in P, R, N, D, S, L -+. Whatever positions are available. You would do this with any auto trans service.
                          Interesting the septics are being quote half what we are but our $ is only 10% below theirs. It seems we never recovered from when we were .45c=1USD
                            Haha, goes to show how much VW know, I asked a 'technician' and he said you need to raise it up on the hoist and accelerate to get to 6th gear.
                            Now I know I can do just as good as a job.
                              Maybe I have misinterpreted.
                              I used to service automatics but that was when powerglides & trimatics were common.
                              That how-to is done by a home user. Any idea what the VW manual actually says? (but I think I've got it right anyway - anyone else have a clue?)
