Please help me identify coolant leaking part
  • Please help me identify coolant leaking part
    Hi
    My car started loosing all of the coolant as it reaches operational temperature. It suddenly just started today. I have located plastic part from where coolant is running down and steam coming out too.
    Please help me identify what is this part by pictures.
    Thanks in advance.
    3.jpg - Google Drive
    2.jpg - Google Drive
    1.jpg - Google Drive
    Vagcom codes are
    VAG-COM Version: Release 409.1-S
    Chassis Type: 1J - VW G/J/B Mk4
    Scan: 01,02,03,08,16,15,17,19,22,35,46,56
    Address 01: Engine
    Controller: 06A 906 033 AF
    Component: SIMOS33 1.6l 2V 00AT4083
    Coding: 00033
    Shop #: WSC 01271
    WVWZZZ1JZ2W481205 VWZ6Z0A3820669
    2 Faults Found:
    16706 - Engine Speed Sensor (G2: No Signal
    P0322 - 35-10 - - - Intermittent
    17698 - Coolant Temp Sensor at Radiator Outlet (G83): Signal too Small
    P1290 - 35-00 - -
    Readiness: 0010 0001
    Address 02: Auto Trans
    Controller: 01M 927 733 JH
    Component: AG4 Getriebe 01M 4830
    Coding: 00000
    Shop #: WSC 00000
    No fault code found.
    Address 03: ABS Brakes
    Controller: 1C0 907 379 J
    Component: ABS FRONT MK60 0103
    Coding: 0001025
    Shop #: WSC 01271
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Skipping Address 15-Airbags
    Address 17: Instruments
    Controller: 1J0 920 806 C
    Component: KOMBI+WEGFAHRS. RB8 V17
    Coding: 03722
    Shop #: WSC 00000
    Address 19: CAN Gateway
    Controller: 6N0 909 901
    Component: Gateway K<->CAN 0001
    Coding: 00006
    Shop #: WSC 01271
    Address 46: Central Conv.
    Controller: 1C0 959 799
    Component: 1Z Komfortgerát HLO 0001
    Coding: 00259
    Shop #: WSC 01271
    1 Fault Found:
    00929 - Locking Module for Central Locking: Front Passenger Side (F221)
    27-00 - Implausible Signal
    End --------------------------------------------------------------------------------------------------
