G-8VXWWTRHPN Significant rear camber - are the rear springs sagged? - VWWatercooled Australia
  • Significant rear camber - are the rear springs sagged?
    I have a MKIV 2004 2.0 Golf with the rear beam suspension. As far as I can tell the car is stock standard (not lowered) however the rear has noticeable camber and is scrubbing the inside of the tyres.
    I checked to see if the stub axle has been shimmed (no) and the springs look like the originals.
    I'm thinking the rear springs are sagged and that has caused the camber.
    Has anyone experienced this on the rear beam suspension?
    Trash Hauler
    BMW 330i M Sport 2006
    Golf MKIV 2.0 Lt 2004
    What psi do you keep your tyres at and do you rotate them every 10k kms?
    Sent from my Nexus 5 using Tapatalk
      Tyre pressures are 28 PSI
      The car has 139500 kms and i have had it for 2000 kms so have no idea how long since they have been rotated but doesn't look like they have ever been rotated
        28psi is way too low. They are under inflated and hence the noticible wear on the inside. VW says 28psi is recommended, but it's purely for comfort purposes. I would pump the tyres upto 34psi at a minimum.
          28 is not enough.
          Generally the rule is, 2 x rim size + 2
          15inch = 32
          16inch = 34
          17inch = 36
          18inch = 38
          MK4 GTI - Sold
          MK5 Jetta Turbo - Sold
            Thanks for the advice - will up the pr sires to 34.
            i will post a pic tomorrow to show the camber - any advice is appreciated.
            cheers
            TH
              Noticed the same on the Golf we have, regarding the camber, ours is 2003 model.
              Would be interested also to find out about this.
                There is anywhere from 1 and 1.5deg on the rear as standard.
                Keep in mind. Toe in Or out is more often the cause of wear then camber.
                Bora gone
                Vento VR6
                MKIV GSW TDI
                7P Touareg TDI
                  I'd have thought being a beam axle, the camber would be relatively constant.
                  Typical ride-height changes wouldn't affect it too much, if at all.
                  '07 Transporter 1.9 TDI
                  '01 Beetle 2.0
                    Yeh beam axle makes the camber static.
                      Thanks for the input - I didn't think the beam suspension can be adjusted for toe or camber.
                      Attached are the photos of each side - the left is more noticeable than the right. I am thinking the springs are sagged.
                      Thoughts?
                      TH
Name:	Left Camber.jpg
ID:	1827775Click image for larger version
Name:	Right Camber.jpg
                        Could have had a hit and bent the beam.
                        Bora gone
                        Vento VR6
                        MKIV GSW TDI
                        7P Touareg TDI
                          It won't make any difference if the springs have sagged. It's a beam axle.
                          I'd say the beam is probably bent.
                          '01 Beetle 2.0
                            Any ideas on the best way to confirm a bent beam?
                              Get under and have a look, or ask a suspension shop to have a look for you.
                              But as others have stated there is no adjustment in the rear.
                              MK4 GTI - Sold
