Help: GTI cut out while running and wont start
  • Help: GTI cut out while running and wont start
    Hi Guys
    I am at work at the moment and just had a call from the missus driving the GTi that it had decided to turn off while driving and now wont start. From the sounds of it the car cranks strongly but wont kick...
    the car has had issues starting before but will usually start after a longer period of cranking - sometimes it will run quite poorly sort of spluttering once it does start.
    Is this something someone has had happen before..? I havent had a chance to look over the car yet - i will likely be spending the night in the shed trying to get it going as it has just been towed home.
    Aside from checking the usual (fuel/spark and air) is there an electrical device (Maybe the MAF) that could break and cause this...?
    Cheers guys
    Pete
    My guess it will be a coil pack. If you have no spark that will be it!
    Goodluck.
      Is the coil pack something breaks down regularly...? My thinking is that it seems to be something that has gradually been wearing out rather then just break as the starting difficulty has been getting progressively worse...???
        Take a spark plug out and re connect it to the HT lead- Turn it over, if there is a spark then it is not the electrical system.
        Maybe a fuel issue.
        I suppose you have to hear it first to see if it sounds like it is trying to fire up.
        1993 MK1 CAB ! Work in Progress........
          just spoke to my brother (he just went up to see if he could get it running but cant so it towing it back) and he said there is absolutley no kick in it. Cranks and thats it. Which is what it has done to me previously.
          I do need to see the car to check the vitals, just trying to work out if there is something that goes quite commonly on them...???
            They have 4 coil packs so for it to stop completely, I would think it's something further up the line.
            Is there a a key symbol lit on the dash? This would indicate that the immobiliser is the culprit, a highly likely cause IMO.
            Everyone says it but VAG-COM is going to be the quickest way to diagnose the snag.
            If it is the MAF, disconnecting it will make it run.
              Whats the quickest way to get a VAG COM...? I looked into it a week ago and just put it off (didnt really have the time to try and find something anyway...). i was more thinking if it had to do with spark then it wouldnt be a coil pack but the ignition module...
                If all the sparks have gone and there is no immob symbol on the dash. You could maybe borrow an amp from someone, the one in the side of the airbox.
                You may be able to find someone local that has VAG-COM. It depends on where you are in Sydney. I know Golfloon has it in Camden. There have to be others though. Make your location a bit more specific.
                Maybe you could join the RAA for a quick check if it's not expensive?
                It may be another sensor, like a crank/cam position sensor that has quit or the plug fell off?
                EDIT VAG-COM is sold by Guy Harding in Brissy. That would be the quickest way to get it I think. The software is downloadable from Ross-tech.com. Cheapo cables from ebay only work with basic versions of VAG-COM and aren't a patch on the real thing. There may be a reseller in Sydney.
                  Did u recently work on your airbox/ Air intake? I had the same thing happen 2 me it turned out to be the one of the airbox connectors wasn't clicked in porperly.
                  1999 Golf GTi - SOLD
                  2005 Golf GTI (2 Door) - SOLD
                  2014 Octavia RS400 Combi
                  1997 Golf GTI (Daily/Track Hack)
                    Troubleshooting ideas in the link.
                      i recently serviced the car yes. i didnt change the air filter, just blew it out but i did diconnect the top cover from the intake pipe - which means i had to disconnect the MAF and the temp sensor thingy. But it seems to be something that has been developing since then... guess i will have to wait until tonight to see what i can find.
                      H100VW - what are Guy Hardings details so i can give him a call.
                      Oh, and i live 15 mins from Camden at Leppington.
                        Harding Performance:
                        Harding Performance Pty Ltd
                        63 Fisher Street
                        East Brisbane
                        Queensland 4169
                        Tel Local: 1300 730 949
                        Tel Int: + 61 7 3392 2980
                        Fax Int: + 61 7 3217 4941
                        email: info@hp.net.au
                        MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
                        2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
                          Go and see Matt/Golfloon then. Mention Watercooled
                            Fixed. Had a chat to Brenton P (DVR68U) and worked out that the temp sensor in the airbox breaks quite commonly - which makes the car shut down.
                            So after spending 1 hour to clean out the shed to push her in, had a look under the bonnet and wadayano, the plug was disconnected from the airbox. i must have not connected it properly when i replaced the air filter... oops.
                              lol all good, as long as it wasn't anything serious
