Clutch kit required, Bora V6 4mo 2002 BDE engine
  • Clutch kit required, Bora V6 4mo 2002 BDE engine
    Hi Guys,
    My clutch has packed in. I think its probably the slave cylinder as the pedal has gone to the floor. Its not the pedal as I've checked and its all still intact.
    Who would you recommend for replacement parts? I plan on doing the DMF while its all in bits and probably the chains, guides etc.
    Any recommendations for parts suppliers would be great.
    Steve
    to test the clutch put it in second gear and start the car . If it starts moving the clutch is still ok . Sometimes the bleeder block fails :
    Clutch Bleeder Block - 6 Speed - Euro Revolution
      What if its the Clutch slave? Would I get the same result by starting it in gear?
