Car is MK4 golf 1.6L engine code AVU
My car is burning a small amount of oil on acceleration once warmed up and so smokes a bit I know it’s the valve stem seals but wont be able to replace them till at least December as way to busy at work to do the job and will do the timing belt water pump etc then.
I currently have 5w40 in there but it is using it up way too quickly. I put in an addative (basically thicker oil) which has helped a lot. Would using Castrol high milage 15w50 damage it as it might be too thick or will it be ok?
Many thanks
zeroasylum
Many thanks
zeroasylum
