Stage 2 tune ecu mk4
  • Stage 2 tune ecu mk4
    Volkswagen MK4 Instrument Cluster Stage 2 ECU KEY Combo Jetta GTI Golf GLI | eBay
    Will this ecu work in my car?
    Mk4 gti 2002. I have the supporting mods for a stage 2 tune.
    Cheers Jason
    Cheers Jason
    That won't work mate and by the time you got it all here and fitted in the car you could have a Custom-Code tune from me.
    No ECU from an American GTI will work on an Australian one. They never got the AGU engine and we never got ME7 ECUs in ours.
        Thanks heaps for you help.
        How much do you charge for a stage 2 tune?
        What do you mean by custom-Code tune? Can the tune be customized?
        Cheers Jason
          Cheers Jason
          http://www.custom-code.co.uk/ You'll have to do some reading on the scene mate and catch up I wouldn't offer you a customised tune, as the cost wouldn't be in line with the extra power.
          There's nothing wrong with the file I already have.
          The price is $849.
            how much power can you get out of a stage 2 tune with full 3inch exhaust system?
            Facebook Page http://www.facebook.com/ChesterJohnPhoto
            Flickr http://www.flickr.com/photos/chesterjohnphoto/
              If I saw one that made 210 hp at the crank I'd be very impressed. The exhaust system doesn't really hold them back, it's the turbo is very under sized.
                That's not much better than a stage 1 tune. What's the difference between them? Could you but the boost up to 20psi on the ko3 turbo? Is there a difference in fuel economy between the tunes?
                Would I have to send you my ecu?
                  The reason there's not much power, is the size of the turbo. It can't be run harder, just makes heat. If you want more, you need a bigger turbo.
                  Phase 2 makes more mid-range due to the better flowing exhaust.
                  You can make it produce 20 PSI if you want to be changing it out often.
                  The economy will be much improved over stock on either tune. You'll not see that around town really though. If you were driving out in the sticks, you'd see a good improvement in the distance you got on a tank.
                    I recently got stage 2 from Gav and highly recommend it, the difference is slight between 1 and 2 but it is noticeable.
                    I also upgraded to a K03s turbo which is only slightly bigger but did help a bit.
                    the thing you have to ask yourself when choosing stage tunes is basically..
                    stage 1 is for a standard car which you want a bit more power.
                    stage 2 is when you have the usual bolt ons (exhaust/down pipe and maybe a pod filter etc(not needed but sound cool )
                    stage 3 is when it gets serious, you need many alternate components(turbo,manifold,fuel system,piping changes, clutch, some engine internals like con rods may need upgrading etc) which is a BIG jump in power but also cost.
                    stage 2 is plenty of a daily street car where you don't want to be too concerned about breaking components
                    I am currently getting 7.1l/100km in my mk4 GTI stage 2 with k03s and 3" down pipe and pod filter.
                      Definitely need to do this soon to save me some petrol and have some fun ahah
                      The lowest I've got my gti down to is 8.8L/100km and that's at 110km/h for just over an hour
                      __________________________________________________ ______
                      MK4 GTI - Reflex Silver - <<<Click for Build!<<<
                      -Previously Owned a MK4 1.6L Golf - Reflex Silver
                        Wow
                        With my tune I get 8.8 around town, 10.5 flogging and 7.2 highway.
                        MK4 GTI - Sold
                        MK5 Jetta Turbo - Sold
                          It usually sits around 9.5L/100km around town and up to 14L/100km if I put my foot down haha
                          So a tune will make a huge difference
                            I am guessing my readings are borked then as at 100 it reckons 5.1-5.7!!! (its all estimation i guess though?) totally stock
                            On a seperate note where are people sourcing ko3s turbos from as i am having a hard time sourcing a unit at anywhere near a half decent price
                            Im asking around from the below for post 2000 cars as i believe these came with the ko3-52/53 which are supposed to have a marginally higher efficiency level? For the most part they look the same apart from actuator pressure needed?
                            A3s
                            mk1 Audi TT's 180hp
                            VW Beetle
                            Skoda octavia VRS (dont know what config made it over here)
                            I have all the relevant engine codes but alot of this was gathered from UK and US sites which doesnt always mean it ended up here....
                              you dont take the reading AT 100kmh..it is on the dash as 7.1l/100km,
                              I got mine from Gav so not sure where except Ebay gumtree or even Camden GTI or a local VW/audi wrecker
