So my mk4 gti has a few electrical troubles, i'm not sure if they're all related but ill just list them and see what you guys think, could be a simple fix I don't know.
-Windows wind intermittently, they'll move for a few seconds then stop, then start, and stop until they're at the top/bottom. At first I thought it was trouble with the drivers side switch, but the same happens when you use the switch on each door.
-The rear left door has two issues. The lock doesn't work and neither does the window motor. Have replaced the motor with a new one but no result. Tested the plug to the motor, its receiving power but wont turn.
- Boot lock does not work. only locks manually.
-I don't have remote entry. The doors will unlock when I turn the key (except the rear left), but they will not lock. I lock them manually every time I leave the car. I have had the drivers side locking module apart but cant find anything wrong with it.
I really don't know where to start with these issues and don't really want to pay an auto electrician to look at it. Are the windows and locking mechanisms controlled by the same main module? could it be bad earth? I've checked the earth wires under the battery and in the b pillars.
Please help!!!!
Please help!!!!
