if you can stretch it not that you really have to check some of the companies in the States, you should be able to get a Bilstein HD suspension kit for about that money landed in Aussie.
But from experience doing a Bilstein Suspension and H&R Springs is really fantastic. Drive even better than standard and handles far better.
The bilsteins worked for you? Don't know if the guys that put mine in got them wrong, but h&r's with Bilsteins on my 03 Bora 4Motion was damn stiff. Sharpened it up a fair bit, but I couldn't take the ride. Maybe I'm getting old!
Word to the wise tho, I switched out the Bilsteins for some Konis and they don't work with the H&Rs at all. Bumpstops a go go. Guess that's cause the Bilsteins are gas and the Konis aren't?
Dunno whether the H&Rs are 40 or 50mm (is there any way to tell?), but with the Bilsteins the suspension was rock hard, and with the Konis it was as soft as standard. And because they're lower than standard springs (about an inch or so) they bottomed out badly all the time with the Konis in.
I think the Bilsteins were the sports version from memory. A bit of a shame cause I've now gone back to the standard springs with the Konis, and my main aim in changing the shocks & springs was to sharpen up the steering and now I'm (almost) back to square one!
cheers
Marcus
Not 100% suer on how to tell the diffence between 40mm and 50mm H&R springs, other than maybe the height.
Does sound abit bizzare that your suspension bottoms out, i'm running Bilstein PSS adjustable in my golf, the front is currently on it's lowest setting, and they have been rebuilt last year. And they have never bottomed out at all.
