Steering noise
  • Steering noise
    I'm hearing a clunk or knocking noise when the steering wheel is fully locked.
    I can feel it more when I'm reversing into my driveway, just as I'm about to take off. Getting very annoyed with it.
    I'm thinking maybe the CV joint.
    Does anyone know what else it might be?
    Thanks
    Haz
    harry,
    i got that noise when my front control arm bushes were out, replaced them with whiteline - awesome
    MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
      How much did that cost ya?
        ill get back to you i cant remember i think around 150mark...but ill double check
          Thanks Franky
          Also, where do you get whiteline products from?
          Haz
            I had the same problem, I used ECS ones from Audvolks in Clayton Sth. I think they were around the same $$$'s
            Originally posted by Whubbsie
              Are they easy to fit?
                IT wasn't an expensive job to get done but it's not something I would tackle...
                  you will need to drop the control arms out takes prob 15min, about 6 or so bolts per side, you will need a press to press out the old ones, and to refit new ones... not to hard if you know a mate with a press
                  mk4 the mods begin for round 2 hahahha
                    My control arm bushes are also stuffed
                    Where can you purchase whiteline bushes from in Syd and who did the fitting?
                    I am located on the Nth Shore of Syd and need a little work done besides the bushes, (both thermo fans are stuffed) if any one can recommend a mechanis i would be grateful.
                    Sorry for hijacking you thread
                    4Mo
                      yeah i have the same problem. only at full lock.
                        Just out of interest about how many km's do you guys have on your cars?
                        Snowy.
                          Snowy I'm @ ~ 90K
                            Only 52,000k's
                            That's why I'm curious to see if its a common problem.
                              Ok, I'm at 56000km and no weird noises.....yet.
