Double Din Head Unit install help!
  • Double Din Head Unit install help!
    Hi there
    Is there anyone that can provide a link on a step by step process how to install a double din head unit in to a V5 Bora? Preferably one with pictures if possible.
    Is it difficult to install and removed the old one??
    Any hints or tips will be greatly accepted
    Old headunit you either need keys or 2 pieces of wire bent into a U shape to insert into the holes each side (i used a cut up coat hanger)
    Funny/pocket above can be removed with a good tug.
    Same as the cup holders if needed.
    Plenty of diy on here
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
      What do you need to know? Main issue is finding a cage that fits the unit. After that it was straight forward. One of my main suggestion is to find an ISO adapter and solder that to the head units wiring harness therefore it makes it a plug an play and very easy to go back to stock.
      VWVortex.com - DIY: MKIV Double DIN Radio Install
      2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
        I was looking in to getting this one for my car: ($269) JVC KW-AV51 6.1inch Touchscreen DVD USB iPod - KWAV51
        I was wondering what adapters and the such i would need for it?
          My suggestion is one of these.
          ($14) Male ISO to Bare Ends - APP7201M
          The unit will come with its adapter and then you solder the two harnesses together. Then it is plug and play
            Okay thanks a lot, so you solder the harness with the head unit to this adapter and then it is just ready to go? I mean would it match up as the head unit now is really old cassette (Eurovox) and i still a bit confused. Any shedding of light would be awesome!
              Repco sell jvc to ISO adapters for 20 bucks
              plug and play ....
              the blaupunkt I got cost 325 and plugs straight in and has Bluetooth and much better Iphone integration ... As in album art etc
                Just be careful with the switch and unswitched power with those as VW is reversed to everyone else.
                plug and play ....
                  Just did a double din install the other week too!
                  The head unit you purchase should come with a standard ISO connector...
                  Like LeStig said, just pickup a VW to ISO connector: then hook the two together without any soldering needed!
                  If you are purchasing a double din unit, i found the ebay fitting kits to be pretty good: you can buy a package with the VW ISO connection and fascia kit for about $25 bucks
                    I think your confused there?
                    ISO is the connection on the car side. The brown and black connectors. He would need as leStig suggested a JVC to ISO connection for that head unit. I've never seen any head units come standard with ISO connections either.
                      Blaupunkt LA500 .... Fitted it Friday afternoon.... Uses the original VW ISO plugs .... straight into the unit.... NO adapters or extra wiring required and all functions work ..... DVD needs an additional permanent grounded source to operate.... Overrides "safety feature" of no screen display whilst moving ....
                        same with clarion
                        '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
                          So which models can we get that doesn't need any adaptors or extra wiring?
                          And which one blends in with the lighting colour of the golf mk4 2.0L sport?
                          Thanks,
                          K.
                            Any recommendations on a double din fascia/bezel to finish it nicely? I bought an aero pro kit but the bezel is crap
