For the past 3 months, my 99 Golf GLS (1.8 ltr 20V) has been:
- Trying to idle at 400-600 RPM, yielding a very rough idle (and stalling on cold mornings).
- Jerking - almost bunny-hopping - when feathering the throttle near the off-throttle condition (while trying to maintain the speed limit).
- Refusal to step-up the engine idle for increased load (i.e. air-conditioning on means the vehicle will more than likely stall).
The problem is causing the ECU to shut-down other functions:
- The cruise control will not set.
- The air-conditioning compressor does not remain active for any length of time (meaning you get moderately cold air at best).
The car has been to Essendon Volkswagen, Barloworld Volkswagen (Glen Waverley) and South Yarra Volkswagen. The things that have been done/suggested are:
- Change from Shell V-Power (98 RON) to BP Ultimate (98 RON) fuel.
- Innumberable ECU resets.
- Changed over a vacuum line.
- Cleaned the throttle body.
- Replaced the MAF.
Car is still the same, and I am sick of shelling out cash, and dealing with the arrogance of the Volkswagen service departments. The issue is not throwing an error code, so they seem competely inept at fixing the problem.
Any suggestions on what it could be guys? At the very least, maybe a suggestion for where I should take it?
Cheers.
- Replaced the MAF.
Cheers.
