Hi all,
So it seems that my engine's head may have carked it after I lost all my coolant recently. Filled with water today and on its first start, when the engine reached full temp, I found water in two of my spark plugs (two nearest the throttle body) evaporating water and gurgling away. Spark plugs have been removed and they are wet. That being said, oil is not milky and looks fine. (little burnt but nothing alarming). There was no usual noises or temp rises while it was running.
I lost my coolant three weeks ago I was nearing home when the car started to shudder around the 2000-3000rpm mark. Power was definitely down until I reached past 5000rpm. Got it home and noticed smoke. Opened up the engine and there was two hoses split and spewing out coolant.
After inspection, I also discovered that the back t-pieces were crusty & brittle (inside was rusty) and the small one near the reservoir snapped in four places. I know that these cars aren't the best in aussie weather conditions so I was recommended to have some stainless steel T-pieces made up from Enzed. (Factory t-pieces vs Custom ones (significantly bigger) )
To make them fit, hose lengths had to be adjusted. (End result here )
I replaced this hose which connects the heater core to the cylinder head with a hose that didn't have different sized ends (one size generic heater hose). That hose had different sized ends along with the t-piece also having different sized outlets. Maybe that's whyy now be why I have this issue. Expensive mistake?
My first thoughts are a head gasket issue. Water in a combustion chamber is never a good thing. And getting it out is the next problem because water doesn't compress and the manifold is so damn high that it couldn't even spit out if I crank the bastard.
Anyone think it's not a head gasket?
I can remove engines/gearboxes etc, so I'm thinking of removing it and then sending it off for an engine rebuild?
Any ideas/ball park figures for cost? I'm obviously going to have to also budget for a timing chain, water pump, pulleys etc. If the heads are getting redone/rehoned, is there any else I can have done relatively cheaply I can have to the engine to improve it?
Any help is heaps appreciated. ****ting bricks here right now as I prepare for the worst
Looks like I'm going to be badly off budget for my house deposit too
Thanks.
Thanks.
