Hey Guys,
Have an Audi A3 8L. The problem I have is with the fans. Before you tell me to read the threads as been covered many times. The problem is when you turn the car to accessories (ignition on) the fans start pulsing. Now I dont think they should be doing this. Also when the car is turned on the fans are pulsing.
Whats has been done:
- Checked all fuses, even the ones on top of battery
- Bypassed Low speed fans with resistors (been covered a 1000 times in other posts)
- Checked the radiator sensor and bypassed - low speeds work fine without car on. As soon as ignition switch on and wires bridged the fans pulse and then will speed up to high speed.
- Have replaced fan control module
- Temperature sensor has been replaced.
So basically low speeds work and high speed however fans still pulsing. Have also replaced both fans as my main larger fan eventually failed.
Anyone have any ideas, have not been able to search much on the net.
Chris
Chris
