Best wheel alignment in Melbourne
  • Best wheel alignment in Melbourne
    Hi guys,
    I'm just wondering what experiences you have had with wheel alignments.
    Where the best places are to have a wheel alignment in Melbourne and what stores to stay away from? (Costs will also be helpful)
    Just a quick question, are all front wheel drive Mk4 golfs only front wheel adjustable? Meaning only a two wheel alignment needed?
    Front has toe adjustment and the slightest amount of camber adjustment (say like .05 deg).
    Rear has some give with the bolts - can be used to equal toe a bit or move the beam left/right. You cannot change rear toe individually. Cannot change rear camber. (refer to camber shims, can be used to fix toe upon lowering an MK4)
    Some good info:
    VWVortex.com - MkIV Camber plate list
      Some good info:
      Thanks for the information !
        If you are not having excessive toe or camber wear on the rear I wouldnt bother touching it.
        front is next to no camber adjustment. just toe to correct really
        Bora gone
        Vento VR6
        MKIV GSW TDI
        7P Touareg TDI
          Given the lack of adjustment on these cars a specialist is not really warranted.
          Unless you are seriously low or have some specific settings in mind, Kmart is pretty cheap.
          MK4 GTI - Sold
          MK5 Jetta Turbo - Sold
