Advice on servicing mistake
  • Advice on servicing mistake
    Got my car mk4 gti serviced for it's 105,000km, and days after blowing blue smoke, turns out they had a new mechanic on and overfilled the oil, went back to get it drained, ended up being close to 2L excess oil.
    What concerns should I have apart from the issue that there was no supervision on the new mechanic, is there any issues that may arise from this? drove probably 150kms with too much oil in the car.
    Just so I have some knowledge in case anything goes wrong,
    nothing seems to be out of place, no smoke and running fine,
    cheers
    CURRENT: DBP Mk4 Golf .:R34 no. 187 (WOOKY)
    Mods: C2 Motorsport Custom Tune | 268/264 schrick cams | Eurospecsport forged rods | JE forged pistons | Miltec Headers back | Higher compression | Engine fully ported | polished balanced crank | Sach Motorsport clutch | Single mass flywheel | Wavetrack LSD | Shortened 4th/5th/6th | etc etc |
    The only thing I can add is that i would ask for a refund for the 2L of oil that wasn't needed.
      thanks team_v
      I checked that, and said they charged the amount that is specified by the manual, so that's not an issue good point though! I'm assuming the young fella was told put "X" liters of oil in, then proceeded to fill it until it couldn't take any more.
        LOL 2L extra.. that is a massive ****up....
          Just get the mistake documented by the garage you had it done by just in case something faults down the line..VDUB...
          BRISBANE / GOLD COAST
            1 Job, he had 1 job
            HAHAHA
              Hmm, maybe he forget to drain the oil, hopefully he changed the filter.
              Performance Tunes from $850
              Wrecking RS OCTAVIA 2 Link
