my son's 2.0l bora starter makes a horrible squeal, only when winding down, no issue when it's starting. is this easily fixed?
noisy starter motor
what do you mean by winding down? as you are turning off the car or just after its fired up? if its just after its fired up and then the noise happens the starter motor will be sticking in and need replacement unit... VDUB...VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
Probably a dry throw out bearing. My Beeza is currently doing the same thing. An easy fix apparently but the starter motor has to come out to be lubricated.2001 Bora 4 Motion Sport now used by number two son
yeh ive lubed up a few. worth a try. especially dsg gearbox cars but some have gone past and need a new unit...VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
Mine does this, re conditioning the starter did not fix it. Lubing it made it better for a short while.
My wife and I call it the "duck"
I thought of replacing it about 8 years ago but thought I might see how long it lasts.MK4 GTI - Sold
MK5 Jetta Turbo - Sold
mine makes that noise on and off.
thought about replacing the motor, 5 years later the noise has gone and motor is all good still, no lube, no refurb.
I just try to keep some money aside for that day when it does let go...
I just try to keep some money aside for that day when it does let go...MK4 GTI - Sold
The squeal is usually associated more common in manual gearbox cars.The reason being clutch dust dries out any lubrication in the starter motor itself and starter bush in the bell housing, always a good indictor of how a driver uses the clutch....change the bush when lubing the starter...always helps..cheers steve
Originally posted by volksMuller View PostThe squeal is usually associated more common in manual gearbox cars.The reason being clutch dust dries out any lubrication in the starter motor itself and starter bush in the bell housing, always a good indictor of how a driver uses the clutch....change the bush when lubing the starter...always helps..cheers steve
How would you tell it it looks OK ? There is no dipstick, just fill till it overflows.
I changed mine a while back, after that shifts were a lot smoother, especially at high revs into 2nd.
I used Redline MT 90. I even have about 700ml left over should you need some. And the 17mm hex tool to remove the drain bung.MK4 GTI - Sold
Originally posted by JustCruisn View PostHow would you tell it it looks OK ? There is no dipstick, just fill till it overflows.
another question, is the engine oil vw specific (2.0l) like my other son's TD T5?
eric
