Hey all my fuel pump went a couple days ago and from vw its dear as hell. Anyone know of a place thatll have one to suit a bora 4 motion. Maybe a performance one if possible
4 motion fuel pump
Re: 4 motion fuel pump
Drop into an Autobarn store with your engine code and they should be able to order you a new fuel pump
Engine code will be something like AGU or AKL for example
Sent from my GT-I9305T using Tapatalk 2'01 Mk4 Golf GL, Engine swapped to 1.8L GTi motor, Whiteline Swaybars, Nolathane & Pedders Bushes, K&N Oversize Pod Filter, 2 1/2 inch Cat back exhaust
4 motion pumps are different as the tank is a saddle over the driveshaft.
It'll look like this with the pipe that connects to the lift pump from the other side of the tank.
If yours is really dead, I have the one I took out of my S3. It was still working. Might get you back on the road while you sort something else out?
Don't know if the bora is the same, but you can get the pump motor itself out from the housing and bits around it. The electric motors by themselves are about a hundred bucks. Autobarn should be able to get you one. I got one from Repco for the mk4 golf
They are different Stan. That short pipe goes direct into the pump, which is different to the 2wd ones.
Cheers Gav, looks like a new pump then
