experiencing knocking noice after coilover installation?
  • #16
    Yea its a really weird noise, deffs a knocking sound though. Changing my bushes this weekend so I'll see if that fixes it.
    MY MK4 BUILD
    • #17
      I have a similar noise going on.
      Changed gearbox mount since I thought my motor was hitting the power brace under neath the car.. still knocks but not as bad. Was hoping the dog mount would be worn but gav pulled it out tonight.. looked perfect.
      My swaybar is actually touching the subframe though.. enough to take paint off it.. gav thinks I need longer sway bar links. They're already the mondeo ones..
      Will have another look tomorrow and see if I can diagnose this.
      All other bushes have been replaced
      • #18
        i was chasing a knocking in my mk1 thinking it was a top mount issue, then lower ball joint even thinking it was a cv, but when i had my coilover out the knock was in that! there was a locking threaded cap that holds the shock in the lower tube that had wound out causing the shock to move about 10-15mm up and down within the coilover assembly, thread locker and tightened it up and good as new!! now i just have some cheap nasty coil overs in but could be worth a look?
