Hi all,
After replacing the front brakes on my MK4 1.6L to 312mm from a Bora 4mo (second hand hubs/carriers/bearings/disks/pads/everything that's needed to do the swap), I had really strange amounts of negative camber and toe in on the right side (left side was good).
Here's an image note the previous values are how they were straight after the swap, final values are how they are now with toe adjusted so I could at least drive the car
(note the left side toe was fine vs previous values, the values listed are a happy medium (right side toe was +15.1mm after swap))
So, I'm wondering if anyone could give me any information if the hubs/carriers would do this? What could be bent?
Are 4mo front control arms different?
Surely someone else has put 312mm brakes from a 4mo onto a 1.6 before
You probably think it's stupid me doing the swap to 312mm but I'm going to be doing a 24v VR6 conversion and the brakes needed changing anyway.
