Indicator Issue's
  • Indicator Issue's
    Just this morning, turned indicator on, turned the corner, it switched itself off as per usual then started making the ticking noise in a random and frequent sequence. Stayed like that for a bit then I turned indicator on again it turned off then came back on. doesn't seem to make indicators flash, just making the ticking noise?
    Anyone know why?
    CURRENT: DBP Mk4 Golf .:R34 no. 187 (WOOKY)
    Mods: C2 Motorsport Custom Tune | 268/264 schrick cams | Eurospecsport forged rods | JE forged pistons | Miltec Headers back | Higher compression | Engine fully ported | polished balanced crank | Sach Motorsport clutch | Single mass flywheel | Wavetrack LSD | Shortened 4th/5th/6th | etc etc |
    Pretty common mk4 thing.
    Can either be a dirty connection on the stalk or hazards bottom, or the relay is stuffed.
    Mines doing it too.
    Pretty confident mines the stalk so going to shot some connection cleaner down the hole
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
      My S3 went the same way and I pulled the switch apart and fixed it. There's a relay in there for the hazards and another of the indicators.
      You can work it out with the lid off by switching the hazards on and observing. I clean the contacts on the other relay.
      Been good for 18 months now (famous last words). Hardest part was getting the switch out. Needed the stereo out first and no keys for it.
        ok so it's fixable, but it's a pain in the ass basically? haha
        I'll see what I can do, thanks guys
        Have any helpful links fellas?
        Cheers dylan and gav!
          Vortex for links ha.
          I narrowed mine down to the indicator by removing the hazards switch fuse, clicking was still there so assumed it would be the indicator side of things
          Bora gone
          Vento VR6
          MKIV GSW TDI
          7P Touareg TDI
            Oh yeah thats a good idea dylan, cheers
            Just another joy in owning a almost 10 year old car haha
              Happened to me twice now but fixed both times with some contact cleaner where the indicator stalk goes into the steering wheel column. Can't hurt.
              2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
                You could always do what I did. Nothing. My Bora used to do it all the time. Got over 250,000k's on it now. It just stopped doing it after a while. Although as Gav said famous last words.
                  Hazard switch is also your flasher can on these, it can go pear but as some have mentioned the stalk switch can go bad. Id be looking at the easy hazard switch first.
                  Cheers\
                  Jmac
                  Alba European
