Hi,
Just bought a 99 V5 Bora.
It was running a little sluggish, so decided to do a service on it.
Put a K&N panel filter in, started the car back up and it started running really rough (limp home mode).
Got her hooked up to the diagnostics test and spat out these:
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 166720km/103595miles
Address 01: Engine Labels: Redir Fail!
Part No: 071 906 018 K
Component: MOTRONIC M3.8.3 HS V02
Coding: 10031
Shop #: WSC 01317
VCID: 1B3E54A3896B9FC0D47
5 Faults Found:
00668 - Supply Voltage Terminal 30
07-10 - Signal too Low - Intermittent
00553 - Mass Air Flow Sensor (G70)
31-10 - Open or Short to Ground - Intermittent
00282 - Throttle Position Actuator (V60)
28-10 - Short to Plus - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-10 - - Intermittent
01247 - Activated Charcoal Filter (EVAP) System Solenoid Valve 1 (N80)
Readiness: 0000 1001
76
Coding: 10031
Shop #: WSC 01317
5 Faults Found:
