please help!
About a month ago out of the blue my golf 4 1.8t started running rough. All of a sudden it will start sputtering quite badly and when I stop at a light it will stall. it then starts back up again and I wait for it to happen again. I have taken it in to the problem and they say all the ecu said is their is a problem with the air fuel mix. They then said the solution could be to replace the breather hoses and valves.So..... this is what I've done.
Replaced all hoses in the breather system plus the three way valve and the puck valve.
cleaned the MAF sensor
cleaned the throttle body
cleaned the heat sensor in the inlet manifold
cleaned the inlet manifold
it has near new spark plugs
replaced fuel filter
ran an injector cleaner in the fuel
has anyone got any ideas? I heard a loud clicking noise coming from the charcoal filter valve so I checked the bypass valve and it seemed to be stuffed could this be the course? Please help this is really doing my nut in!!
cheers, Neil
cheers, Neil
