Door won't open, central locking & interior lights don't work
  • Door won't open, central locking & interior lights don't work
    G'Day ,
    I have recently purchased a '99 GTI Golf from the auctions. While the majority of the car (body and mechanicals) are in good condition, the electrics are presenting a few issues.
    The main issues are:
    Central locking doesn't work from the key and when locked from the drivers door window control panel, all doors lock and then unlock themselves straight away (don't stay locked).
    The interior lights work when switched on manually, but not in the door selection. The red lights on the door cards work at random.
    I'm guessing this is related to the door modules? From what I've read on the net there is a cracked solder problem for the central locking and maybe a stuffed microswitch for the interior light? I've had the fuse box out and all the connections and wiring look ok there.
    The other main problem is the rear L/H door doesn't open from the outside. It is opening from the inner handle ok. Will this be the outside handle cable tension being too high, or could it also be related to the door modules?
    I had this happen to Mr a few weeks ago. Check fuse 14 I think it is. It's located in you drivers door. Replaced it and everything worked
    Sent from my GT-I9100T using Tapatalk 2
      Was pretty stoked thinking that might work... but nope... I'm thinking it's the door modules with cracked solder.. Anyone else got a quick fix that doesn't involve me and a soldering iron
        The door handle pulls a cable, the cable attaches with a black plastic cli. I suspect this clip has come off. Pull the handle out and look into the gap to see if it is connected. Handle will have no resistance if cable is not connected. You maybe able to reconnect without removing anything.
        taligentx.com: Passat - Dlm 10 skinmounted...
        MK4 GTI - Sold
        MK5 Jetta Turbo - Sold
          for the central locking. Can you roll the windows up with the key in the door lock? Have you tried slamming all the doors, front hood and rear hatch?
            Thanks for the link, good photo's there. I can't see the black clip with the door handle pulled out, so will start there.
              Thanks for the info, I'll try that tonight.
                Unfortunately none of the suggestions have helped to sort out this issue.
                I will be pulling my door linings off and checking the solder on the circuit boards / checking microswitch operation.... sigh
                  The RAF spent thousands training me to solder if you are worried about that, I don't mind doing it if you can get the parts to me.
                  At the airport on earlies monday-wednesday and lates thursday-saturday
                    Who do you work for at the airport - I'm at Virgin M/Watch
                      Small world, I am very familiar with ife on your 777s probably tells you who I work for. Have you been on board recently?
                        Nice one! May catch you sometime
                          this issue is also similar as to when the body control module (also known as comfort control module ) has an issue,cany other internal items not working properly?
                          also try fuses 13 and 14
                          My build thread here: 1.6 sr into 1.8T http://www.vwwatercooled.org.au/foru...-8t-63249.html
                            Yeah, lots of internals not working.. including the interior lights, rear wiper is intermittent, mirror controller only adjusts RHS as well as the central locking. Will Google the BCM to see what it does...
                            Is there a fix - or just replacement?
                              Dunno if the bcm (or comfort control module) can be fixed
                              It lives up under the dash - you have to remove the plastic trim under the dash, and it is tucked up high, like instrument cluster high. It is held in by a couple of screws and has one or two cable bundles plugged into it.
                              google and vortex are your friends.
                              Your symptoms of various internal features not working are a pretty classic sign of this.
                              this is for passat, but sounds like your woes:
                              VW Passat Comfort Control Module harness repair | HeadFUZZ
                              check for bad earths and water damage first
                              They are not all that expensive on ebay (around $100), but get the right one.
                              I also believe that a dealer can sort them out, no idea of cost (it's a dealer, so not cheap, I'm guessing....)
