Clunking in rear after lowering on KWs
  • Clunking in rear after lowering on KWs
    After installing my KWs and removing the rear perches for more lows there's been a metal clunking sound in the back when going over bumps. I jacked it up and everything feels tight except for the spring which can twist around when the car is all the way up.. could that be it? It only seems to come from the right side though which is weird.
    VW Bora V6 4motion
    On my mk3 my rear beam hits my exhaust.. Could that be it?
      When the suspension is at full droop are the springs still 100% captive? If not it could cause you grief
      Also check the bolts at the top mount. If they are a little loose you can experience clunking.
      FOLLOW US ON FACEBOOK
        bushes to your rear beam? the rear beam actually hitting the chassis or something?
        Bora gone
        Vento VR6
        MKIV GSW TDI
        7P Touareg TDI
          I had this. Albeit 2wd and it was the bolt under the perch (unless they're completely removed not just the adjuster?) on the drivers side.
          I tighten them and no more rattle.
          Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
            thats a good point. have you removed just the adjuster or the whole perch? if the whole perch make sure the spring actually sits in the bottom mount nicely when compressed under the weight of the car
            Bora gone
            Vento VR6
            MKIV GSW TDI
            7P Touareg TDI
              After lowering my a3 the exhaust pipe hits the axle
              Might be the case?
              Radiators are over rated
                Thanks for the insight guys.
                When at full droop the spring can't fall out although it can twist around.
                I removed the adjuster AND the perch.
                I'll jack it up on the weekend and take a look at the rear beam, exhaust, etc.. Thing with the exhaust is that the muffler is on the left side (don't know how the whole exhaust snakes around though?) but I can only hear the sound from the right side..
                VW Bora V6 4motion
                  Drivers seat makes everything sound like its on the right side. Get someone else to drive and sit in the passenger seat, see if it is louder on the left.
                  MK4 GTI - Sold
                  MK5 Jetta Turbo - Sold
                    When my wife drives I try and listen real hard for the sound but can barely hear it on the passenger side..
                    VW Bora V6 4motion
                      So.......................... I checked out my suspension today in the rear and it was all tight with no play. About to give up I realised I'd made a noob mistake- I had put the spacer on the wrong way after I took my rear adjusters out! The chamfer of the wheel hub was sitting up against the flat part of the spacer leaving some play in the wheel (danger danger). No wonder the car handled like poo and I hated driving it.
                      So far it seems the wheel wasn't buckled or the wheel bolts bent/stripped but I'll get this checked properly when I get my alignment redone.
                      Took her for a test drive and she felt as smooth as stock. Finally got to thrash her around the industrial area and thoroughly enjoyed it.
                      (Usually after I jack the car up the suspension problems disappear for a while but come back after driving a few minutes.. So far this hasn't happened so I hope this was the actual problem *fingers crossed*)
                      VW Bora V6 4motion
