Was looking into fitting an k&n kit on my mk4 R32 and just wondered what people thought? Is it worth it and which model??
K&N high performance air intake on R32??
If you mean a pod - only if you have it where it can get good quantities of cold air. Be aware that any unenclosed filter (pod included) is illegal in most states (not sure on Qld, but check).
Benefits - largely noise. You might get a bit better intake flow, but unless you're also doing exhaust work, you're just moving the bottleneck in that case.
Be aware that if a filter of one particular kind allows higher flow, it's probably not filtering as well as the original alternative. Changing filters is a compromise.Nothing to see here...
I am currently trying the VW Racing high flow panel filter in my Stg1 Tiggy. Have had it in a week & initially didn't notice a difference apart from a slight increase in intake noise (which i kinda like!). I now feel as though after a few hours driving time, adjustments (learning?) have been made & torque feels to be up a little. Got better than usual fuel consumption as well on a day trip down the coast with a massive paddle-board on the roof racks (7.3l/100)!Current: MY18 TRANSPORTER CrewVan, Indium Grey
Originally posted by BHardstaff View PostWas looking into fitting an k&n kit on my mk4 R32 and just wondered what people thought? Is it worth it and which model??
In which case, it's generally regarded as a bad idea as the oil will foul your MAF and they're not that cheap to replace.
This will be less of an issue if you're looking at the kits that replace the stock air box that have the filter at the end of the intake that sits close to the front of the engine bay. But still probably not worth doing.
Then there's the kits that have the air filter that sits behind lower bottom grill of your bumper.
For the few hundred dollars that these kits will typically cost. I don't think it's worth it.
But if you're still keen, I would research the dry type of filter systems. Like the one from EVOMS:
BMP
#171 / 200
Originally posted by thepowercosmic View PostIn which case, it's generally regarded as a bad idea as the oil will foul your MAF and they're not that cheap to replace.Nothing to see here...
i have a neuspeed CAI on my r32. The car is more responsive, takes about 1l/100km less and the noise is great. The air filter is a K&N POD filter that sits in the bumper behind the passinger side bumper grille so its getting proper cold air. I did have a POD in place of the airbox but that killed the MAF.
So if you want one of these go for a proper one like mine or dont do it at all. THe ones that sit in the airbox dont really make much difference since its not getting proper cold air
NEUSPEED Race Series Cold Air Intake : Neuspeed®1991 BMW 318is RED E30
Originally posted by balkanac View Posti have a neuspeed CAI on my r32. The car is more responsive, takes about 1l/100km less and the noise is great. The air filter is a K&N POD filter that sits in the bumper behind the passinger side bumper grille so its getting proper cold air. I did have a POD in place of the airbox but that killed the MAF.
Originally posted by BHardstaff View PostNot sure what to do now because my wife has brought me a K&N typhoon 69 cold air intake induction kit type for my bday and she got it in from the uk, cost a bit and K&N told her it will b good and do the job??
You will be fine.
Originally posted by h100vw View PostFit it or sleep on the couch! They are oiled correctly from the factory, just be careful when you service the filter and don't go mad with the oil.
You will be fine.
